lukej101 Posted June 22, 2005 Report Share Posted June 22, 2005 I just bought a refurbished one of these but it has only come with sonicstage simple burner and the manual i got said to use Open MG. Where can i get this (i need one that wont download files from the internet after the original download) and also will this act as the driver for the Net MD.Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Christopher Posted June 22, 2005 Report Share Posted June 22, 2005 Hi, just download Sonicstage 3.1 (also referred as the Connect player) from connect.com - here's the link..http://www.connect.com/download_cookie.html Quote Link to comment Share on other sites More sharing options...
lukej101 Posted June 22, 2005 Author Report Share Posted June 22, 2005 I use my NetMD on another PC, i got the full download version (because the other PC has no internet access) but when i install it it has a error, something to do with WMP codecs or something like that. Can anyone help? Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted June 22, 2005 Report Share Posted June 22, 2005 I use my NetMD on another PC, i got the full download version (because the other PC has no internet access) but when i install it it has a error, something to do with WMP codecs or something like that. Can anyone help?←read thesegreetings, Volta Quote Link to comment Share on other sites More sharing options...
lukej101 Posted June 22, 2005 Author Report Share Posted June 22, 2005 Thanks very much. Not only did i get this working but i found a package that should of been delivered outside my door with 20 MiniDiscs in it. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
The Low Volta Posted June 22, 2005 Report Share Posted June 22, 2005 glad to have helped...though I'm not sure what I said tthat made you go to the front door Volta Quote Link to comment Share on other sites More sharing options...
